Hello again!
It is time to continue with some more information and pictures of the Scania fire ladder project.
The next step was to dismount the cab completely. As shown in the picture below there are a lot of plastic in the lower part of the cab in the EMEK model…….
It was a lot of sawing that needed to be done……
Now it will soon start to look like something useful….
After some measuring it was clear that the front axle had to be moved 11mm to the front. When I moved the rear bracket for the leaf spring to the front as much as possible it was exactly 11mm! So it turned out to be a very easy and quick thing to do!
Some parts of the EMEK cab has very poor detail level such as the foot steps for example.
I had to drill some holes in them in order to make them look more realistic.
Other parts however are very good, I am very pleased with the moulding of the cab for example. In my opinion it is at least as good as Italeri.
Next ”big” operation in this project will be the engine. The engine from the Italeri model is a V6 and thats just impossible to use in a Scania
After some thinking I decided to ”convert” the V6 into a straight 5 cylinder engine. So it was time to use the saw a lot once more!!
To be continued…
Best regards
Håkan
