Hi Daniel,
very beautiful Scania. How would it be, if you would document the building report here in the forum with pictures?
Sandra
This way the chassis stand now.
I have rubbed off the painting of the hubs.
The engine which perhaps do not come once, because he goes think I place to make for the battery of the leds which comes.
Daniël
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »SCANIA-FAN« (17. Januar 2007, 13:48)
Original von SCANIA-FAN
Daniël
If u build the trailer also u can put the Battery in the Trailer and connect the Truck with the Trailer over the original Power and Pressurecables...
If u build the Truck without a Battery but with a cable connection from outside u can build the Truck on a board and put the cables in the frame as pressure cables and then along the wheel through the board to the batterie.
Or if u dont want a permanent Connection and no Battery u can took one the boxes at side of truck or even build one of these with a hinge to open it and into the box u can fix this plugs which u can buy in H0- Train-stores.
So u can open the box and connect the plugs or u can close the box and there are no cables...
only a few ideas.
if u want to know more details just write it to me...
greetings
Dominik
