Montag, 8. Dezember 2008, 19:54
Scania T580 6X4 heavy haulage
Hello!
It has been a while since I posted anything here so it is definitely time again. This time it is about a project I finished a couple of month ago. So today this model is finished but I thought I might as well post how this project was made from the beginning to the end.
The “role model” is a real truck that is running in Latvia. It is a Scania T580 heavy haulage truck that mainly transports heavy machines such as excavators and wheel loaders in Russia and Latvia. It is a very high spec vehicle with hub reduction axles, air suspension, overdrive gearbox etc.
For this project I decided to use an EMEK cab. But it turned out to be some work since the Scania T-version only is avalible as T144 in EMEK, so I had to rebuild it together with parts from an R580 cab as well.
More will follow soon…..
Best regards
Håkan
Dienstag, 9. Dezember 2008, 21:33
Hello!
Time for an update. Been working with the front grille. I had to combine both EMEK and Italeri parts from both Scania 4-series and R-series to be able to build up the T-version front grille.
Have also made some test assembly of the powertrain and chassis.
To be continued…..
Best regards
Håkan
Mittwoch, 10. Dezember 2008, 13:28
Hi Håkan!
Dette har du veldig godt gjørdt! Er dette egentli lett til å skøpe modeller i Sverige?
Jeg har av og til ebay-sverige besøkt, men der er nesten ingen salg på lastebil modeller.
Hjertelig hilsen fra de bedre tyskland = bayern
Klaus
Da wo man das Bier aus Masskrügen trinken kann,
weil´s so gut ist und nicht aus Reagenzgläsern.
Freitag, 12. Dezember 2008, 19:38
Hej Klaus,
Ja det kan finnas en del på Tradera ibland. Annars är det hobbyafffärer som gäller.
MVH
Håkan
Freitag, 12. Dezember 2008, 19:44
Ok time for next update!
This time about the interior. It is also a mixture of EMEK and Italeri parts.
And finally a couple of pics of the truck:
To be continued…..
Best regards
Håkan
Montag, 15. Dezember 2008, 20:30
Hello again!
Time for a new update of the T580 project. First step of the paint job is finished. I also got an idea that it should be possible to open the bonnet so I added two hinges from an Italeri 4-series Scania.
To be continued….
Best regards
Håkan
Sonntag, 28. Dezember 2008, 21:43
Hello again!
Second round of the paint job is finished and have started with the graphics.
More will follow soon.
Best regards
Håkan
Sonntag, 4. Januar 2009, 11:05
Hello!
New update. Now it was finally time to start the real building and use some glue.
It is not so much that remains to be done: a couple of antennas, mudflaps, decals and some other smaller things.
I have also decided to rebuild the EMEK trailer and also a JOAL CAT wheel loader in scale 1:25.
Best regards
Håkan
Sonntag, 4. Januar 2009, 20:43
hello,
nice job, I have always said that emek has lot of potential to build great model, but of course need great modeller to do it :hand:
So you find out joal caterpilar?
Dienstag, 6. Januar 2009, 22:23
Hello again!
Now the decals, mudflaps and antennas are in place also.
The work with the trailer and CAT wheel loader has started as well.
More to follow….
Best regards
Håkan
Mittwoch, 7. Januar 2009, 20:01
Hey Hakan
Really Nice Rebuild of this Scania the trailer looks really great too now :ok: :ok: :ok: :ok: :ok: :ok:
Greats David
Respekt the Oldschool 8)
Dream of Swedish Perfektion =D
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Dk2007« (7. Januar 2009, 20:01)
Freitag, 9. Januar 2009, 19:49
Hello again!
It is time for an update of the Cat wheel loader, it is soon finished….
Also some work on the trailer has been done including painting:
More to come….
Best regards
Håkan
Freitag, 9. Januar 2009, 21:46
Hi Hakan,
its makes fun to look at your work and to follow your report.
Congratulations for this very nice Model-Truck.
Greetings
Harry
Montag, 12. Januar 2009, 21:10
Hello!
There has been some progress on the trailer. Some stripes and decals and also some load securing brackets on the sides.
I also decided to use some chains to the load securing.
Best regards
Håkan
