Im Bau: chassis 10x8
Freitag, 7. März 2008, 15:31
chassis 10x8
please people:
look at this, and hint and tips are most welcome:
Dont worry about axle 1, Im using tq20a along with KFS driven frontaxle
now
compared to this:
It seems that the 2 front driven axles from kfs are wider than then the rear axlesP
the "wrong" axle are the middle one. will have to make the axle pass under the driveshaft.
I've counted the 2 frontaxles from KFS to be 11 cm in with, and the rear ones to be 105 mm.
Thats 0,5 mm in difference.
How do I overcome this problem? :bang:
Sonntag, 9. März 2008, 09:46
this hapens because italeri wheels are too narow, they not represent real 315/70-22,5 or 315/80-22,5, but something like 275/90-22,5 :bang:
so, you can simply gnore this, as most of the time, or, you can order new KFS rear wheels which are larger and also have more heavy design
Sonntag, 9. März 2008, 10:40
Or you can simply cut a little inward part of italeri rims (the small tube wich is on axle) like me on my DAF XF.. whels get more closely to chasis and it looks OK.
Realname: Frank
Sonntag, 9. März 2008, 12:37
KFS front driven axles are wider then other axles. I'm bilding Mercedes benz and i used KFS front driven axele and its wider allmoast 2 mm in each side then original revell axle. :verrückt: :bang:
Warum mit der Bahn fahren,wenn man mit LSD fliegen kann......
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Scania« (9. März 2008, 12:39)
Sonntag, 9. März 2008, 15:22
Im going to wreck my head over this.
the only solution I can think are to narrowing the frontaxles, or the hubs. :idee:
