Well, as you can see above I am getting to grips with my new computer software.........photos are a bit grainy though......
Anyway as you can see in the above shot I have the EC-145 light panel grafted under the nose.
In this lower shot you can see that I have finished all of the door seals on the rear fuse. There is an inner and outer set. This was quite a challenge as I used fine thin strip glued around the edges and then re-glued with very thin CA. This was then flodded again with Mr Surfacer and then the edges filed down to a scale width to match photos. Note also on the lower floor now there is a new piece glued to the bottom. This is the new lower fuse structure and as you can see, the rear of the belly needs to be extended back to correct the profile.
Unfortunately this next photo I took here isnt very good either, but you can see the antenna's fitted forward of the upper engine intake cooling scoops. I initially used the kit ones but they were too square, so I made little plates on the cowl, drilled 2 small holes and inserted a suitably bent piece of fuse wire to the correct shape. I got a bit ratty with it but am happy with the difference it has made.
Next to recieve attention was the main rotorhead and blades ....again!
Now I definately dont like the BK-117 kits rotorhead or blades.....call me fussy, but I have come too far now. The rotor dia is a bit small and the blades are not good enough. I have decided to go with the highly modified EC blades and hub. First off the aerofoil section was changes as the 145 blade is flat on the bottom whereas the BK is not. Then the 'bump' was put in the leading edge near the root and the shape and length was changed as well as tip detail. I also added a new trailing edge and hub attach point details. All in all each blade has about 25 new pieces in it so far..... The hub was improved by adding new ends. there are still qite a few new bits to go on, but I need a break from them for a few days.....they are driving me nuts. As you can see (just)I have started adding the photoetch from the Reniassiance set on the blade roots. Not much to see, but there are star shaped nuts on the other side as well, I have only just started adding these on one blade.
This shows the centre verticle console being made along with the main hub. I couldnt balance it in the model to take the photo as it kept falling over by the time I got back to the camera!
Well, thats where she is now. I have really enjoed getting back into her again.
Cheers and thanks for dropping in
